Does anyone run MTNK's mapping on a silber Pro
T
Apr 17, 2010
78
15
8
I was told by bullydog that mtnk turbos has a map for people to run on their silber bullydog turbod pros. They said it clears up the initial stumble that the silber mapping has when your on and off throttle. My sled rarely does this but im more curious if there is anyone who is running this map.......
Thank you!
snosfun
120
N of Great Falls, MT
I would imagine Silber will have an update map for next season on the axys.???? Maybe???
They did have updates on the pro kits.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
kgra
237
89
British Columbia
Yes I had Shawn at Mtntk put his mapping on both my Silber Turbos in 14 and 15 and they worked very good no blubber at all
Good news!
Do you knoe what version of silber map were you running with issues?
How much boost and what elevation are you running with mtntk tune?
Thanks
C
Ckale
158
18
18
Buena Vista, CO
Also looking into doing this, to fix the high-elevation bog issues with the Silber map. After speaking with Shawn lately at Mtntk it sounds that his mapping has fixed those who are having these issues. If anyone else could chime in on their experience it would be helpful.
R
roni87
513
213
I Falls, MN
Mapping
Slapped on my old boondocker box from when my sled was rinning a Rktek kit this week. Added 10% fuel to most rpm ranges 5500 and up. I believe 12-13 at 8500...finally runs good. Can get off and on throttle without a bog or complete stall out that kills momentum.
Piggy back controller is what I need to run. Way too lean on silber map.
diamonddave
Chilly’s Mentor
5,577
3,890
Wokeville, WA.
What elevation is this at? And internal or external waste gate??
What year sled? Stock motor?
wellfed777
2,226
412
83
Oregon
i'm confused are you saying that the silber map is way too lean in general in that rpm range
or that in your application it's too lean in that range ?
R
roni87
513
213
I Falls, MN
Sled
In my application I've found its too lean...but I was experiencing the same problems last April in revy with stock pistons and stock reeds.
Sled now.
Ssi top end with spacer.
Vforce 3r reeds ftom axis
Boondocker turbo intake.
3 or 4 gal 100ll
150-310 primary spring
73g rooster weights
120-200 sec spring
48-44f helix
Boonie piggyback box...for na sled, no boost or aux controls
Also 4000 miles on bottom end.
I'm not here to bash silber. Just want everyone to get there sled running like it should.
C
Ckale
158
18
18
Buena Vista, CO
In my case sled (2015 pro 155) is all stock except for 2015 Silber kit, with the latest map, clutching setup per Silber's instructions. Sled is virtually new, have checked/cleaned exhaust valves, clutches, reeds, etc. It is the external kit, have used the 7lb spring as well as the 5lb spring with the same results.
This three describes the problem well:
http://www.snowest.com/forum/showthread.php?t=405880&highlight=2015+silber+bog
