I will try and keep this as short as possible.
The sled is a 2006 Apex MTN with the stock rear suspension and a MMI 8" rear wheel kit. The chaincase is rolled. There is a Boondocker turbo on it but that isn't the problem. It had a 162" by 2.5" camo extreme track.
Last year I speared the track. For some reason my rail tip caps disappeared. I was travelling down the trail at about 50 MPH in soft loose snow. There was a couple wind drifts across the trail. I hit a couple and it speared the track. It locked up instantly and slid to a stop. We towed it out and hauled it home. As always I put things off and didn't work on it until a couple weeks ago.
I purchased a used track with the same part number as the one that was speared-9944M. I pulled the suspension out and installed the new/used track. Now the track hangs way down with adjusters maxed out. I thought maybe the used track was stretched out so I ordered a new track. In comes the 162" by 3" Camo Extreme. I installed it today and WTH. It hangs just as bad. I checked the tunnel and all seems good. Nothing has moved on the chaincase, driveshaft or drivers. The distance between the suspension mount bolts is 31.5" the same as another stock sled that my dad has. I have looked at this thing for hours comparing the two sleds. I am at a loss here.
PLEASE help and give me any ideas as to what could be causing this problem. I never had a problem adjusting the track before I took it out. Is there anything in the suspension that can flip or cam over and cause this problem?????
HELP!!!!!!!!
HELP!!!!!!!!
