Upgrade to Premium
Reply
  #1
Old 01-31-2008, 03:49 PM
collom7 collom7 is offline
Currently: Not set.
Basic Member
collom7 is an unknown quantity at this point
Default M7 Mod Questions
I Have Heard Alot Of Good On Here About The Reloction Brakets For My 06 M7. Is There Anyone Else That Makes Them Other Then Holtz. I Would Rather Find Some Cheaper Ones If Possible.
Also How Do You Measure How Far In The Plastic Nut On The Scondary Is In. And What Tool Do You Use.
Thanks
Rate this post: Yes | No
  #2
Old 01-31-2008, 05:41 PM
superfast superfast is offline
Currently: Not set.
superfast is an unknown quantity at this point
Default
As far as I know holz is the only one. You should be able to use a micromiter to measure the white nut
  #3
Old 01-31-2008, 06:14 PM
Currently: Not set.
Basic Member
Default
where do i measure from?
  #4
Old 01-31-2008, 06:52 PM
Togwotee Madness Togwotee Madness is offline
Currently: Not set.
Basic Member
Togwotee Madness is an unknown quantity at this point
Default
I forget what the spec. is but you might want to drill and tap a hole for a set screw to engage one of the holes in the nylon nut. The nuts will not stay in place and this is a simple fix
  #5
Old 01-31-2008, 07:04 PM
mtn_extreme mtn_extreme is offline
Currently: rebuilding "everything", damm economy
mtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond reputemtn_extreme has a reputation beyond repute
Default
I don't run them, I run sledjunky's suspension fix.
  #6
Old 01-31-2008, 07:41 PM
spudman720 spudman720 is offline
Currently: surfin BCR
spudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the roughspudman720 is a jewel in the rough
Default
SLP has a relocation kit also. Think it is about 65$
  #7
Old 01-31-2008, 09:27 PM
bxtreme4life bxtreme4life is offline
Currently: Not set.
Basic Member
bxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond reputebxtreme4life has a reputation beyond repute
Default
I wouldn't waste my money on the brackets, never installed them on my last 06, have them on my new 06, and can't tell any difference. Also had friends that put them on and said they couldn't tell a diff. just my 2 cents
  #8
Old 01-31-2008, 10:23 PM
Currently: Not set.
Default
I put the brackets on and noticed a big difference softened the suspension a bit and no more track bind but I also did the geo mod.
  #9
Old 01-31-2008, 10:24 PM
TheOnlyBFC TheOnlyBFC is online now
Currently: Not set.
Basic Member
TheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond reputeTheOnlyBFC has a reputation beyond repute
Default
Couple the bracket together with the Geo mod and you will be ridin on pillows compared to the stock suspension.
  #10
Old 01-31-2008, 10:56 PM
sledhead_583 sledhead_583 is offline
Currently: Not set.
Basic Member
sledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant futuresledhead_583 has a brilliant future
  #11
Old 02-01-2008, 12:57 AM
bgreen776's Avatar
bgreen776 bgreen776 is offline
Currently: gimping around
bgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond reputebgreen776 has a reputation beyond repute
Click Here to Register
  #12
Old 02-01-2008, 08:37 AM
Currently: Not set.
Basic Member
  #13
Old 02-01-2008, 10:20 AM
threetoecrow threetoecrow is offline
Currently: Not set.
Basic Member
threetoecrow is an unknown quantity at this point
  #14
Old 02-01-2008, 09:40 PM
Mtntrax Mtntrax is offline
Currently: Not set.
Basic Member
Mtntrax is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
