After about 6 or 7 good pulls with the sled building boost I start to get oil coming up the vent line and out of the vent. Is it possible I just have to much oil in the tank or is there something that could be wrong causing to much pressure in the tank and pushing it out.
It is gravity return. In the first pic that is the lower hose coming off the bottom of the turbo. The hose is bigger than the outlet nipple on the bottom of the turbo.
Thats correct. You want a big line without elbows. If you look at Boondocker or Boost-it the drain is straight down. If you look at 2012 Silber kit it has a 90 off the turbo and a small drain. The Silber guys have these vent pressure problems. On his 13 kit he increased drain size.
Yes, you need a larger drain line. At least 1/2" port. As the turbo RPM increases, it creates pressure from the oil draining and if it can't flow quick enough out of the center section it will puke it out the vent...
