i applaude fasttrax/union bay for trying to come up with something for us when cat wont.
BUT....
the pricing seems like alot.
not bad mouthing fasttrax just showing them the consumers point of view.
one question i do have is... are these two clutches (p85 and the 3 tower cat) the same diameter????
i ask this wondering if the poo clutch is smaller in diameter will you lose some top end/full shift/overdrive ratios.
will fasttrax machine someones p85 if they own one? and offer the bolt, washer, alignment bar and puller as and accessory item kit??? if so how much???? ski
You Bet-happy to set up a clutch you supply, as long as: it is NEW! it is pointless to put all this effort and coin into a hashed out clutch--if you want best bang for the buck, start with a new clutch and stay on top of the maintanence! AND, it has to be a CFI clutch-the older style clutches are made for a smaller crank dia and do not leave enough meat after the machining to have faith in!
Yes it is expensive, in part because these(clutches, bolts, puller, alignment bar) are custom made --we are building this stuff-not buying it from China and re-selling it. We are putting a ton of time and effort into each clutch to produce taper surface finishes comparable to or better than OEM so there are absolutely no fretting or runout issues. If you've ever seen some of the re-tapered clutches out there, you'll know what I mean!
We are using new clutches and they aren't cheap!
Yes, there is a diameter difference although we have seen zero issues from it-the ratios work out very well. The older sleds with taller gearing are considering gearing down a bit to obtain a bit more shift and the folks with the newer (lower geared) models are considering gearing up a tad-there will be a happy middle of the road gear ratio found.
If you send us a new clutch, the cost for machining, balancing, setting up/machining for the b.s.c. and supplying the bolt assy, puller and alignment bar/shim kit will be $380.00.
I'm not going to argue to convince anyone of the value-the guys that have had serious durability problems with the OEM Cat primary will see the value on their own. The performance gains have been a side bonus-longevity was the intent here.
Great questions-thank you!
Curt
