After taking the DD out of the sled i think i understand the problem.
What I notice about mine is that when you put it back togheter on the workbench with the stock bearing, everything seems okay.
But when you put the DD back in the sled and tighten the 16mm bolt from the others side, you will put pressure on the bearing.
This is also why it`s hard to get the cover all the way inn without loosening the 16mm bolt.
So the way I see it, it`s 2 problems: poor quality bearing and 1mm to long driveshaft.
So removing the stock one and spacer and repleace it with the 5203 seems like a bad idea. You will put even more sidepressure on the 5203 that is 1,5mm thicker than the stock with spacer.
But maybe it can handle it.
The best would be to take out the driveshaft an take off just enough to remove the sidepressure on the bearing.
Correct me if I`m wrong.
Haven`t ordered the bearing yet, but i think I`m going for the 4203, and ride with my fingers crossed
