A
I'm getting ready to put my 02 Edge 800 back together after losing a magside
rod bearing. The pistons show very little blowby and look pretty good. They do have some minor cold seizure scratches.(1500miles) So I'm debating if I should replace or run them? I also was wondering if I had warning signs about my motor before it went. About 3 rides before it went I had to change my cold starting procedure.(Add throttle and choke to start it) I use to just choke it for a few seconds then let it idle. Also it started to idle higher than it use to then drop off to low. I don't know if these changes mean anything it just seems odd that things started to happen before it went. I will check for air leaks when I put it back together. It seems if it was running to lean and this was the cause for rod bearing failure, I would see damage to other parts(cylinders,pistons ect) Thanks for any thoughts!
