You are supposed to service the air chamber at least once a year, directions came with the sled.
float_manual.pdf
Y
our FOX FLOAT AirShox are designed using the highest quality materials and most advanced coatings to ensure a long operational life. For maximum performance, FOX recommends the following maintenance schedule:
• Monitor the air pressure in your shock once every other month
• Perform air sleeve maintenance once a year.* (see instructions in Air Sleeve Maintenance section)
• Perform shock absorber oil service (complete shock rebuild) every 3,000 to 5,000 miles**
Of course, maintenance intervals depend heavily on the type of riding and the riding conditions. . The above recommendations are for the average rider. If at any point you feel a degradation of damping or air spring performance, stop riding immediately and identify the cause of the problem
1. Remove the shock from the vehicle.
2. Remove stainless steel reducers and clean with parts cleaner (application specfic).
3. If your shock has bushings & sleeves instead of spherical bearings, they may be too wide on the body end to slide the air sleeve over. I f this is the case, remove body end bushings & sleeve with a screwdriver and/or pliers.
4. Clean the outside of the shock with soap and water. Cleanliness is critical!
5. Release all air pressure from air chamber filler valve.
6. Clamp air sleeve cap eyelet in a vise with soft jaws.
7. Loosen air sleeve, turning it counter-clockwise by hand and slide it down the body.
8. Remove the air piston slyde rings from the air piston.
9. Clean inside the air sleeve with parts cleaner.
10. Inspect the wiper and back-up wiper inside the air sleeve.
11. Replace if damaged or worn.
12. Clean body, air piston seal, air piston slyde rings and shaft with a clean, lint-free towel.
13. Inspect air piston seal for wear or damage.
14. Replace if damaged or worn.
15. Lightly lube the air sleeve cap o-ring and threads with FLOAT Fluid or multi-purpose lithium-based grease (NLGI #2).
16. Liberally lube the air piston seal and slyde rings with a commercially available fork seal grease.
17. Grease the wiper and back-up wiper.
18. Slide the air sleeve over the body until the leading edge of the air sleeve is at the air piston.
19. Install the first air piston slyde ring.
20. Carefully slide the air sleeve over the installed slyde ring and the air piston seal.
21. Install the second air piston slyde ring, as shown below.
22. Carefully slide the air sleeve over the second installed slyde ring and halfway to the air sleeve cap.
23. Refer to your setup sheet to see if any FLOAT Fluid is required for your specific application. . (Add FLOAT Fluid, if applicable, as shown below.)
24. Slide the air sleeve down to the air sleeve cap.
25. Thread air sleeve into air sleeve cap and hand tighten until the air sleeve bottoms in the air sleeve cap. Do not over tighten air sleeve or use tools other than your hands.
26. Inflate shock as described in usi si ng th th e fox fox fox high high high high pr pr esure pump mp on page 3.
27. Dry bushings and reducers.
28. Install reducers in spherical bearings (application specific), or install bushings & sleeve.
