B
Tach quit working 06 summit 600
I start by saying that this is likely caused by me.
The tach no longer works. the odometer displays the word SCALE.
when first starting the oil, temp, and (!) lights illuminate like normal.
The tach needle does a twitch and then doesn't move again.
10-9 MI flashes a few times before SCALE is displayed.
by depressing the RER button everything normal happens, it goes into reverse and lights flash as motor flips direction.
The headlight low beam and high beams operate normally but the Blue high beam light no longer illuminates.
The sled is very new to me, but when I bought it everything worked normally.
I rode the sled 2 weeks ago and then took some of the front plasic off to remove
the gas gauge because it was stuck. After reassembling everything the current symptoms arose.
I have verified that the 2 20amp fuses are good, I have unplugged the tach and replugged it in. I have removed the DESS plug and inspected it, I have unplugged the ECU (except the last BIG plug-too hard to unplug-don't yank on wires)
Ideally I plug my tach into a friend's sled or plug their tach into mine but that isn't an option at this moment.
Has anyone else run into this problem? I imagine that the 800 adrenalines have the same tachometer.
