T
lets see a picture of it upside down and not leaking oil???
But they can do both,that's the issue most people have,they can make this sled allot lighter with some simple things.
Smaller lighter seat,that 30lbs chaincase,the hood & panels look way better not sure if lighter.
I can keep going but you get what Iam talking about,at this point I won't buy another yammi till they address some of the weight.
Curious what you didn't like about the pro climb chassis if you like the pro. Rider position steering and other things are similar between the two. I've ridden both and find them similar. Being a bigger person I just like the stronger chassis. Thirty pound weight penalty is worth it. And my biggest pet peeve with my current sled is the snow and ice buildup and the Polaris is bad also with that. Pro climb is a very clean chassis
The lower opening is where the intercooler is situated. the air intakes are up higher, towards the rear of the hood."The B-TX series is for low elevation boondockers who want a 153” track length and a narrower ski-stance than traditional deep snow models"
The BTX is wider..
I'm curious if the sled will choke itself out in deep snow.. With the air intake being so low.. I can see this causing issues down the road..
I wish Yamaha did a Sidewinder 153 MTX LE. I don't want the wide ski stance of the BTX, and I love the LE color options. Oh well. Guess I'll wait until next year for a new sled.
When is everyone going to finally figure it out
ITS NOT ABOUT THE WEIGHT!
So I was just reading the sidewinder has no front rad.. and has a full length tunnel heat exchanger.. this thing must be 40 pounds heavier than a viper and will be even worse once the snow and ice builds up under the tunnel..
It will likely work better with snow on the intercooler. On My M1100T, I left the screen off and actually ran a carbon fiber scoop (from EVO) to encourage snow collection on the intercooler. I didn't run a charge air temp sensor, but sled feels snappier. Remember if charge temps get high, the ECU will pull timing to protect the engine (at least on the cat). I would imagine Yamaha is the same way...Also how is the intercooler going to work when its packed full of snow?:face-icon-small-con Looks to be in the worst place you could possibly put it.
This will benefit the trail & cross over segment the most. The radiator is the secondary, not the primary, cooling source. Riding fresh groomed, hard as a rock trails, at 35-45mph, my 2014 XF7000 will hover in that 185-195 degree range. Drop the scratchers and we're back to 164 - 170 degrees, gauge mid point, that I like to see. The full length heat exchanger should perform better for us gauge watching trail riders....the sidewinder has no front rad.. and has a full length tunnel heat exchanger.
It'll probly work better than the inter cooler on the Mcx viper.......air had to get through the rad then it would hit the inter cooler.
