2012 Summit/T motion bogey wheels
T
trentvan
New member
Nov 25, 2008
53
1
8
I have a 2012 Summit X and I have done the T motion kit on it. This weekend while out riding I hit a rock on the rear of my track (by the new 2wheel kit bogey wheels) and both bogey wheel gave out and the bearings ripped right through the plastic leaving them both bent to the side. My brother in law has the 2013 Summit X and while looking at his rear bogey wheels they look much stronger and have a spacer that mine did not. When I go to replace the bogey wheels can I upgrade to the 2013 rear axle/bogey wheels?
800Gader
2,315
60
48
Wisconsin
Kit and 13X are the same
My 13X skid, has the same parts as the t-motion kit I'm installing on a buddies sled, including spacer.
ski-doo-it
182
93
woodinville
I have failed wheel bearings far from the truck and decided that 3 or 4
wheels depending on track are mandatory if you ride in those far from
the truck spots.
Did this to everything I ride.
Here's what I did to my 13XM
ski-doo-it
182
93
woodinville
Love the three and four wheel inboard setup. Either of you guys take measurements of were you cut the spacers at?
All 3 small aluminum spacers are 5/8"
The plastic spacers are going to be cut to size depending on the wheels you use. I highly recommend that you use the spacers or at least bearing savers from an XP.
My plastic spacers are cut to15/16". I am using the offset wheels from an XP with the flat side out. I decided to not put a center one back in as it would be very thin( maybe 1/2") but I still might.
OH... I use Honda bearings. They are a better bearing with exact fit and a few bucks cheaper. I included a pic of the part#
IMG_0999.jpg IMG_1003.jpg IMG_1004.jpg IMG_0996.jpg IMG_1030.jpg IMG_0997.jpg
winter brew
4,332
LakeTapps, Wa.
How about the Cat 2 wheel setup? Are the bearings the same ID? If not, is there a bearing that will work? That setup is stout, have installed several on Kmods, dont have any now to look at.
