So my second sled is out in the middle of nowhere at a cabin. Last ride i broke several of the bolts that hold the Y pipe. In an effort to remove the broken bolts i broke a tap off in one of them and i broke a ez-out off in another.
So at this point my options are to purchase a new cylinder and replace. The question is, can you trust a used cylinder, or do i have to purchase new? While doing the work i will also replace the pistons, rings bearing etc.
Second, the threaded part of my secondary that takes the adjuster has some stripped threads. Looks like i have to by the secondary assembly for $349 to fix the issue. So if i have to spend some cash here as well, should i pick up a used stock, or get a 09 or 10 stock, should i chance to a team...
Trying to get this sled back on the trail but not dump tons of cash if i can help it. I only get to ride it once or twice a year.
Let me know, thanks.
