New to axys. Do the handwarms on axys need to be corked to get hot. Did it to my pro and liked it.
I use shrink tube, it works awesome.
Have any of you found a way to remove and replace the stock heaters without damage and make them stick again.
Ya the thumb heaters are pretty much non existent..
Very carefully with a heat gun but you do end up loosing the foam like backer.
So they have a foam backer and still don't get very hot or is corking just alot better.
Once you start taking the hand warmers off, the foam backer ends up coming apart and you cannot re use it.
With contact cementYour painting the heating element?
Yep that is what usually happens to me.
A guy generally it seems, ends up paying a lot more ( New Handwarmers) just to get cork the bars initially-
That is why I asked- seems like they ( the stock warmers) get damaged,peeling them off.
