does anyone know the part number for the updated voltage reg ? or which volatge reg number is the better one ? my current one is the 4011731
4013587 is the latest.
So were you testing the VR the same way when it was cold as when you tested it warm? You may have inadvertently found your problem if there was no reading when cold but it was okay when warm. There should have been some reading even when cold.
Interested in what you find as we have a 2009 700 rmk with the same problem on our group. We are going to check the throttle safety switch by disconnecting and going to make sure spark plug wires haven't come loose from caps.
hmm. sent it to the dealr, they fixed it.... for a bit anyway 200 dollar shop bill ad it ran great for a decent 100 km trip, went to go out with my friends for a off trail ride, got 2 mins away by the gas sation and it started bogging, pulled over and i fouled a plug on the stator side, with that changed it ran good, got gas, went to go leave and it fell on its face, gauges shut off headlight went barely visible (this is 10 mins ago at night pitch black btw) then died, tried starting but would barely idle at maybe 300 rpm and die..... got a tow home and here i am, pretty much shopping for a yammi now, done with this polaris bull crap.... gona see what i can figure out and see if i can get it running to sel or if im parting outI have the same issues with my 08. I have replaced the stator, VR and cap. I now have no lights or gages, idles fine when cold.
I have disconnected my handwarmers in case they were shorted
