What recomended belt with the Team Tied setup?
machz9805
New member
3
Just wondering what everyone is using, or planning to use, 082, 083 or 084? Have a Team Tied on the way for next week, but need to buy a spare belt for this weekend. Just curious if I should go with the 084 or is the cheaper 082 just as good with this setup?
RACINSTATION
7,503
3,459
Idaho
If your center to center is more than 11.5" it needs corrected. In order to work correctly you have to have it right.
The Team is a larger diameter, but it is only a slight difference.
Woody67
1,437
682
Bellingham, WA
How would you go about correcting the center to center on this sled if it were too long?
JBIZ
232
52
Saskatchewan, Canada
Sounds like a LoT of people on here are more than 11.5. I know mine is 11 9/16 probably closer to 19/32. As far as I know there isn't a real convenient way to change c to c.
N
nosajlleb
708
189
Michigan
Trillion dollar question! Take off tcl and bend it in vise. :noidea:
I don't have a team but I shimmed my primary and now run the gates carbon that fits the the old T660 from 2005.
RACINSTATION
7,503
3,459
Idaho
Most that I have seen have an issue with parallelism. The motor is down and back on the right side and this pulls the end of the crank forward to extend the center to center. The motor then has to move.
As you guys have stated, you can't "adjust" the TCL.
type_a_positive
392
70
Mongo Norway
I have a 11.6 c to c, and switched to the XS809. It is about a half inch longer than the 082, resulted in cooler secondary. But I still have the stock secondary, as no one has a team setup for us 0-3000ft (BD set at 19 psi at sealevel) climbers yet.
machz9805
New member
3
So the Team Tied setup won't work 0-3000?
