Gessh..........I hope they figure this out. What happened to the R&D?
We have bushings for Fox shocks in stock and all the others fit. I've even spoke to one customer who used his fox bushings which are a bit tight IMO but they are working and he seems to think they wear and pound out quickly.
Here is my email if anyone is having a question nate@zbrozracing.com or zbrozsales@gmail.com.
Call us or email us if you are needing something.
If using a stock Fox float shock on this kit the upper bushings do not change its still mounting the exact same. On the lower portion or where the shock mounts to the arm we are supplying a machined bushing that fits our stud. The stock fox bushing is made of a soft rubber or plastic material and it can be pushed onto our mounting stud but it is tight. We have had guys use them and not complain but my understanding is they are crappy and wear quickly and become very sloppy.
Tuesday, I do agree with you about the less thread showing strenthens the joint. I do know that my front end is set up with the correct camber and that adjustment is what it took to get it correct. That joint should not be the weak link. I will let you know after I talk to z-broz today on what they are going to do.
