P Drive Clutching 2017 vs. 2018
toms
316
440
CA
www.tomssnowmobile.com
Here are the dyno graphs for a stock Summit 154. 2 of the runs are stock clutching from a 2017 vs. stock clutching for a 2018.
  • st. Ski doo clutch parts.pdf
Rotax_Kid
734
274
Regina, SK
Thanks for the info Tom. I'm curious, does the SAE numbers from the track dyno have any correction built in? Or are those uncorrected numbers for the ~4,000' your shop is at?
Thanks for sharing. Little disappointing considering there's 160+ at the crank. Assuming 165hp at the crank, and 60hp at the track, that's only 36% efficiency...
F
Nov 27, 2007
2,495
712
medicine hat
Tom I see at 50mph the two ramps are about the same hp.. And close to 10 hp over the 17 ramp..When in a climb we mostly see a max speed around 50 mph on stock fourm, or does this graph not cross reference to a hill application..
Be cool to see the tra in comparasion to this p drive primary.. Almost crazy to have such a hp loss to track
G
Feb 9, 2014
126
168
Shuswap
Just to clarify, is this a 2017 and a 2018 sled or are all 3 runs done on the same (2017?) machine with just the parts changed?
If it's the same sled, was the gearing and springs changed to match each years setup as well?
sledhead_24_7
2,482
1,006
Jackson Wy
It is a 2017 machine. Just changing primary weights. To keep as many variables the same as possible. At least last I talked with Tom it was a 2017.
Just a good FYI comparison looks like to me.
10003514
1,237
779
British Columbia
With that much power on the table with minor clutch changes, I'd love to see a clutch kit shoot out. Have a few full clutch kits tested from different builders.
