Note: this_feature_currently_may_not_be_available_in_some_browsers
I installed one as well in hopes of fixing the belt issue. While I haven't been able to give it a full test since our snow decided to turn to concrete, it does move a ton of air as you can see in the pic and my clutches do feel cooler. Before they would sizzle when I would stop for a break, now they don't. Still hot though.
Band-aide for the real problem. The clutches should never get that hot in the first place.
Agreed, but I believe cooling them isn't a bad thing. I just bought the zrp weights to see if that cuts down on temps as well. Next will be a floating secondary.
I think this may help the issue, but certainly doesn't solve the problem. As sideways mentioned, people are still blowing belts.
Hopefully you don't have any starting issues as others have reported by using the blow hole.
What starting issue? Was going to invest in one of these for my 18 with electric start but not if there is an issue with it working with ES. Thanks.
2017 and ski doo puts this out to market.
hope there jets stay in the air
