Shortblock 5555.59
Crank assembly 2859.99
Cylinder 989.99
Total catastrophic 9404.58
Yikes!!!!!!!
How is it that a shortblock no longer includes the crank assembly and cylinders or is your post just that misleading?
The block has crank and pistons. It does Not include the head or gasket kit.
Yep!
So if you install a turbo
break a rod and it goes through case and cracks cylinder skirt..
That would be 9500.00
I could build a twin turbo LSX
For about same amount
Yep!
Or if you leave it stock and rod goes through case at 2,000mi and the schrapnel takes out both clutches.....if only warranty work didn't take forever. FYI right now i bet you couldn't buy a short block anyways.
The dealer is installing a short block in my sons summit G4 as i type.PTO bearing not getting oil,as per dealer.:face-icon-small-dis
i believe there is no bottom end oiling to the bearings in these motors. "permanent" grease is used instead. always been a skeptic of it.
False.
