Went riding today (2015 HCR with BD TURBO) and we left from a low elevation area today (4500) and went up high. When we were heading across the hay fields on the way up once a few times when I would let off the throttle sled ( about mid throttle) and get back into it sled would bog really bad like it had no fuel. One time I let off and it fell right on its face rpm dropped to about 800 and then came back up after a second. Sled ran fine other than these few occurrences. Pulled some longer pulls and it ran like always so im curious if I have a TSS issue going on. Sled always started ran good it never did this at all up at higher elevation. The only thing I have changed at all since last ride was I installed some MDS weights. When I got home i pulled it apart and found that I have two weights that I probably tightened too much and were a little hard to move due to the nut being tighter than it should have been binding the oring. So another theory I have is that the weight not swing as freely as they should combined with the shorter spring that I got causes it to bind for a second as it is spinning down and once it hits idle it fully opens the clutch. I had a set of mds weights on my 2012 that I had a billet spider in and they would get hung up at full shift sometimes and kill the motor. Any thought would be helpful I'm leaving for Island Park in a week and need my sled to run. I have pulled plugs they look good I looked in through the y pipe and the power valve and the pistons look good no signs of detonation
Thanks again
Thanks again
