MPI/SHR 200 HP turbo kit, in stock clutching/shipping $3995...
SHR 850R 180+ hp trail port/can/clutching $995...
SHR clutch kit for summits $195 hi/lo, $150 hi only...
SHR adjustable ramps (45-56 grams tip weight) adj IN sled $195...
Working on motor mount washer to limit movement (part of belt heat)...
Racewerx is working on a engine limiter/support...
3 mm shim helps alignment with engine limiter...
venting is huge...
cut bottom half off clutch guard...
remove lower panel latch (PITA and not needed)...
SHR stage 1 shock revalve...
just a bunch of kewl stuff from your local parts changer...BJ:face-icon-small-coo
venting is huge...
