Looking for suggestions on upgrading in the off season my shocks on my 850 X 154 with Sillier......ready go!
While I could spout out some random brand, I'm going to give you some rationale as to what I think works best and why.
Before I get into that, lets start by saying all the aftermarket suspension manufacturers make a good product. They are all very similar from a functional standpoint, at least as far as "how the damper works". They are all IFP based and the damping circuits relatively similar.
That said, I feel strongly Tom's is your best bet, especially with a turbo.
Full disclosure, I work for Tom (I also work for Silber). I came to Tom as a customer first, having boosted my 850 and finding it really hard to control and a handful to toss around as the weight transfer is completely different with a turbo. Tom has the most cost effective way to get the ski lift under control while still keeping the sled fun. To add, he has been custom valving Fox stuff for the better part of a decade, and it shows. His product is *very* different than the off the shelf Fox stuff.
The problem with Ski-Doo is they rely on torsion bars as the rear track shock spring. This is a poor way to control weight transfer, as they have a funky spring curve. This is why Ski-Doo relies so heavily on their limiter strap for transfer (ski lift). Hell, Polaris doesn't even have an adjustable one on their mountain sleds and you never see them really having an issue when it comes to ski lift or popping up on the snow (and if they do, its mitigated through the rear track shock - RTS).
Tom's kit (and yes, Raptor too) deletes the torsion bar. Tom replaces the torsion bar and undervalved Ski-Doo damper with a highly adjustable air sprung custom valved Fox damper. It also gets rid of the poorly tuned FTS for a Fox Float product.
In a turbo application this lets you set your sled up in a way that there isn't excessive weight on the skis (so its not a handful at slow speed) but then when you hammer on it the rear track shock stays solid, keeping you from transferring excessive amounts of weight and lifting the skis. Remember, with the turbo you don't get the same amount of bottom end transfer due to heavier clutching and the plumbing of the turbo.
How does he do this? A progressive spring curve (much easier to accomplish with air). This is the secret sauce and why I chose Tom over any of the other skid upgrades out there.
Combined with a quick-to-collapse front track shock and you've got a sled that pops out of the snow quickly, is super adjustable (you can vary your spring curve with a shock pump) eand lighter than OEM.
As far as ski shocks go, its all about tuning. I won't lie - all the manufacturers offer something good, and so long as they are tuned correctly, you'll be happy.
Thanks JJ I have heard a ton of good things about Toms and was definitely going to give him a call, but wanted people to give me there experiences just like you did.
So the tortion delete is the way to go? Looks like there are at least 3 ways of achieving this...
Zbroz Exit.....649 (No FTS)
Raptor Ace...1395 (No FTS)
Toms kit....... ???
Ace
Well said JJ. I agree that getting rid of the torsion springs is key.
I see that Toms kit uses a billet rear arm but I have not seen the rocker or how it interfaces with the cross shaft. Can you explain what degree of motion toms rear arm has and can it be locked out like the raptor kit? And does his kit use the stock front arm?
Interesting discussion of the progressive curve on the air shocks. My experience with the air shocks vs coil overs is mostly from mountain biking and it used to be that the multi rate springs could provide a better curve and were preferred for over all ride quality. Like the triple rate springs on the raptors that ramp up through the stroke. That seems to be changing in the mountain bike industry too as the air shocks keep evolving and I’ve heard that the latest generation of rear frame air shocks have really taken the lead.
With the Fox shocks how important do you think the cashima coating is in reducing stiction with such a large circumference and surface area of the shaft (at least it’s a lot more than typical mountain bike shocks)? Or with such a heavier machine compared to mountain bike maybe it’s not nearly as noticeable.
This is the first season I did aftermarket shocks all around and I don’t think I can ever go back....huge difference in how the skid performs and when we rack up some serious miles on whooped the heck out trails over the season I think there is just so much less wear and tear on a guys body. I did break my front skid arm at the upper weld earlier in the year and was concerned that the additional forces on the arm from the coil over FTS were at fault but I run almost no preload and super light compression. The I blew the raptor rear arm apart too and I’m beginning to think the 175s just shouldn’t be doing big airs and I need to take it easier on the whoops lol
I love my Raptors and KMOD skid.
