new 850 products!!
BIG JOHN
1,146
Minnesoooota
MPI/SHR 200 HP turbo kit, in stock clutching/shipping $3995...
SHR 850R 180+ hp trail port/can/clutching $995...
SHR clutch kit for summits $195 hi/lo, $150 hi only...
SHR adjustable ramps (45-56 grams tip weight) adj IN sled $195...
Working on motor mount washer to limit movement (part of belt heat)...
Racewerx is working on a engine limiter/support...
3 mm shim helps alignment with engine limiter...
venting is huge...
cut bottom half off clutch guard...
remove lower panel latch (PITA and not needed)...
SHR stage 1 shock revalve...
just a bunch of kewl stuff from your local parts changer...BJ:face-icon-small-coo
Curious to hear more about motor mount washer. I was surprised to see how much the the engine moves in the mounts on the track stand with no load on it. My Xm definitely didn't move that much.
SHR clutch kit for summits $195...
venting is huge...
BIG JOHN
1,146
Minnesoooota
I have 1 set of shocks for exchange,
so TA is pretty quick...
shim kit is same as XP/XM...
just cal, website is a little behind...
washer will help when ready...
HPS/DynoPort/SPI cans and SPI Ypipes all work with my porting...
no fuel needed for base line kit...BJ
