Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 12-07-2017, 12:35 PM
t-revzr t-revzr is offline
Currently: SENDING IT!!!
t-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond reputet-revzr has a reputation beyond repute
Default 2018 clutch problems..
I went out to cooke city over thanksgiving and believe i was having issues with my secondary. Im running the slp pipe set and went with the springs that were recommend. Black purple in secondary and blue/pink in primary. When going down the mountain after a climb and tapping the break it sounds to me as if the secondary is ratcheting. Some of you may say thats normal but I assure this is not. Only happens down hill and sometimes happens when im not even touching the break going down hill. My track i believe has locked up on me down hill as well after touching the break. I brought it to the gas station dealer exon in cooke and he changed out the primary back to stock for me. That helped a little bit. He took the secondary apart and said that was fine. I would of put the stock spring back in the secondary if i had had it. The spring he would of sold me would of been the one i already had in the secondary and is close to stock anyways. I have the sled home now and installed the stock secondary spring back and I guess I will see what happens.. I doubt the dealer will be able to tell if anything is wrong as they'd need a hill to go down. Thats why im asking you fellas... My track does hang 3/4 of inch sag with no weight on it. I fell like thats definitely to loose. Could that of caused this issue?
Rate this post: Yes | No
  #2
Old 12-07-2017, 01:34 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
Too loose, track was ratcheting. Should be tightened to spec. 1/2-3/8" with 10lbs hanging 16" from rear idler i think is the spec, Atleast it was for the older pros.
Sent from my SM-G925W8 using Tapatalk
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
The Following User Says Thank You to BILTIT For This Useful Post:
Polaris Pilot (12-07-2017)
  #3
Old 12-07-2017, 01:43 PM
Murph's Avatar
Murph Murph is online now
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
Default
Agreed. Sounds like track was ratcheting.
__________________
Missing Digit Motors-- Servicing your 2011-current ProRMKs in Truckee, CA
Truckee's source for BMFab,Camso Tracks, Indy Specialties, Lectron Carbs, Mountain Side Products, Mystik Oil, RAZE Motorsports, Speedcell and other fine snowmobile products
Speedcell Technologies-- Founding Member
Tahoe Nordic Search and Rescue-snowmobile team
  #4
Old 12-07-2017, 02:19 PM
bobback bobback is offline
Currently: Not set.
bobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond reputebobback has a reputation beyond repute
Default
How many miles on your sled at the time?
Read your owner's manual about QD break in and the sound made by the drive system during this time. My 17 made same noise when braking, would make you pucker up wondering wtf was that?! After 100 miles pretty much stopped.
  #5
Old 12-07-2017, 03:47 PM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
Are you positive it isn’t catching or trying to catch the reverse notch? Down hill braking along with the track driving the secondary on descents can cause it.
The Following User Says Thank You to TRS For This Useful Post:
Sage Crusher (12-07-2017)
  #6
Old 12-07-2017, 04:02 PM
Default
180 miles on this sled. Owned a 16 axys never heard this nasty noise before. All my buddies are on a axys to and have never heard this before. You can hear it from 75 to 100 yards away if your sled is off.
  #7
Default
Quote:
I'm not sure... everything in the secondary looks normal to me..
  #8
Old 12-07-2017, 04:04 PM
Default
I will tightening the track up and see what happens.
  #9
Old 12-07-2017, 07:07 PM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
Make sure your secondary is adjusted correctly
Make sure your secondary c-clip is still clipped
Make sure secondary spring is not broke
Sometimes a too soft of a spring in a steep helix will also cause it to slip into the reverse angle
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #10
Old 12-07-2017, 07:11 PM
RMK-King's Avatar
RMK-King RMK-King is offline
Currently: Not set.
RMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond repute
Default
There should be little to no free hanging slack in your track, 1/2-3/8" with 10lbs as mentioned above.
__________________
"Days get shorter,Snow gets deeper,Life gets better"
'19 Pro RMK 850- On order
'17 SB Assault 800
'16 SKS 800 2.6
  #11
Old 12-07-2017, 08:08 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Click Here to Register
  #12
Old 12-07-2017, 08:52 PM
cascadesnowjunky's Avatar
cascadesnowjunky cascadesnowjunky is offline
Currently: doing the snow dance
cascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond repute
  #13
Old 12-08-2017, 01:46 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
The Following User Says Thank You to Teth-Air For This Useful Post:
mountainhorse (12-09-2017)
  #14
Old 12-09-2017, 02:12 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
  #15
Old 12-10-2017, 11:41 AM
2XM3's Avatar
2XM3 2XM3 is offline
Currently: 2016 axys
2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute
  #16
Old 12-11-2017, 06:42 AM
  #17
Old 12-11-2017, 01:09 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
The Following User Says Thank You to Wheel House Motorsports For This Useful Post:
t-revzr (12-11-2017)
  #18
Old 12-20-2017, 05:46 AM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Anyone have problems with 2018 Camso fit kit/front ski bushings? Thread Starter — Snowbikenewbie Forum — Snow bikes Replies — 11 Last Post — 11-18-2017 08:22 AM
Thread — New 2018 home . Clutch issue ? Thread Starter — randall01 Forum — Ski-Doo: REV Gen 4 Replies — 7 Last Post — 11-09-2017 10:39 AM
Thread — 2018 850 clutch cover Thread Starter — Sledneck_1987 Forum — Ski-Doo: REV Gen 4 Replies — 9 Last Post — 10-31-2017 06:17 PM
Thread — 2018 CLUTCH UPDATE KIT WITH LIGHTWEIGHT JACKSHAFT AND CLUTCH KIT, NEW LOWER PRICE!! Thread Starter — Speed Shop Inc. Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 07-13-2017 04:37 PM
Thread — 2018 CLUTCH UPDATE KIT WITH LIGHTWEIGHT JACKSHAFT AND CLUTCH KIT Thread Starter — Speed Shop Inc. Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 03-30-2017 04:09 PM
no new posts
