Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 12-04-2017, 12:32 PM
snobyrd snobyrd is online now
Currently: in memory of Johnny,JAN 23 2011
snobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond repute
Default Cracked rear tunnel
Iv got a 163 thats got a crack in the rear of the tunnel where theres a factory drilled hole in the rolled edge at the end of the inside bracing. Its being brought to a local welding shop to be welded, sled is still under warranty but not putting any faith into polaris to repair it.
Im looking for info on a good bracing kit that i could put on the side ,perhaps with the rolled lower edge to reenforce the tunnel and cover up the repair after welding.
Rate this post: Yes | No
  #2
Old 12-04-2017, 12:47 PM
Murph's Avatar
Murph Murph is offline
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
Default
Any pictures of it?
Might go with a BM Fab rear bumper- they extend down to rolled edge and all the way forward to running board support.
The welder needs to be really careful with the amount of heat used-- you don't want to weaken the tunnel around the weld.
__________________
Missing Digit Motors-- Servicing your 2011-current ProRMKs in Truckee, CA
Truckee's source for BMFab,Camso Tracks, Indy Specialties, Lectron Carbs, Mountain Side Products, Mystik Oil, RAZE Motorsports, Speedcell and other fine snowmobile products
Speedcell Technologies-- Founding Member
Tahoe Nordic Search and Rescue-snowmobile team
Auburn Extreme Powersports--(530) 885-7105 My local Polaris Dealer
The Following 2 Users Say Thank You to Murph For This Useful Post:
mountainhorse (12-05-2017), snobyrd (12-04-2017)
  #3
Old 12-04-2017, 01:44 PM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
I like the Mountain Armour rear bumper (made here in Wyoming) and have it on 4 sleds now and really does good job of tunnel braceing!
gtwitch in wyoming
The Following User Says Thank You to gtwitch For This Useful Post:
  #4
Old 12-04-2017, 05:21 PM
Rick!'s Avatar
Rick! Rick! is offline
Currently: Yeah, winter, I gotcha covered!
Rick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond reputeRick! has a reputation beyond repute
Default
How big a tunnel bag is on it, how many lbs of stuff is in it, and how far behind the seat brace/rear suspension mounting bolt is it?
Pix will tell a story for sure.
  #5
Old 12-04-2017, 07:40 PM
Default
no storage bag or jerry can. The crack started in the rivet hole on the curl where the last inside brace stops.
  #6
Old 12-04-2017, 08:19 PM
Mr. Pump Gas Mr. Pump Gas is offline
Currently: Not set.
Mr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond reputeMr. Pump Gas has a reputation beyond repute
Default
VanAmburg will make a full length custom tunnel brace/bumper combo. Nice piece and very solid.
  #7
Old 12-05-2017, 02:22 AM
LoudHandle LoudHandle is online now
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default
Quote:
Originally Posted by Murph View Post
Any pictures of it?
Polaris and most manufactures use 5052 aluminum for the formed portions of the tunnel which is not a heat treated nor a heat treatable alloy. Welding will not effect it's strength (positively or negatively).
Depending on what direction and how far the crack has propagated, I'd consider stop drilling it and calling it good. As running a weld over the top of the crack will do nothing beneficial other than lighten your wallet and give you a false sense of security. If the crack is not stop drilled and 100 percent fused back together, it has a good chance of coming back.
__________________
ALASKA
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to LoudHandle For This Useful Post:
Sheetmetalfab (12-13-2017), snobyrd (12-05-2017)
  #8
Old 12-05-2017, 11:14 AM
Murph's Avatar
Default
Awesome--thanks for the info!
__________________
  #9
Old 12-05-2017, 12:08 PM
Default
The crack is being welded today, its mostly for lipstick, we're putting a vanamburg product on it to cover up the repair and strengthened up the sides. We get stuck alot and i guess the constant lifting on the bumper has taken its toll. Moving foward, we need to buy rear tunnel stiffeners to avoid this issue.
  #10
Old 12-05-2017, 01:03 PM
Rick!'s Avatar
Default
All good info except the bolded statement.
How does strain hardened aluminum not get its base strength reduced due to welding? Weldability shouldn't be confused with post weld strength.
The Following User Says Thank You to Rick! For This Useful Post:
mountainhorse (12-09-2017)
  #11
Old 12-05-2017, 02:53 PM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Click Here to Register
  #12
Old 12-08-2017, 02:24 AM
  #13
Old 12-08-2017, 08:43 AM
tuneman's Avatar
tuneman tuneman is online now
Currently: is a long track addict
tuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond reputetuneman has a reputation beyond repute
  #14
Old 12-08-2017, 10:18 AM
  #15
Old 12-12-2017, 06:35 PM
  #16
Old 12-12-2017, 10:03 PM
Snowbird11 Snowbird11 is offline
Currently: Mentating
Snowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond repute
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — cracked tunnel 155 Thread Starter — glowa Forum — Polaris: Pro-Ride Replies — 13 Last Post — 03-16-2015 02:59 PM
Thread — HELP! Cracked Tunnel Thread Starter — snowboatboy Forum — Polaris: IQ Replies — 3 Last Post — 03-14-2012 06:10 PM
Thread — Cracked rear tunnel Thread Starter — phatboy07 Forum — Arctic Cat: M Series Replies — 9 Last Post — 12-05-2011 10:03 PM
Thread — cracked tunnel Thread Starter — boondockerpro16 Forum — Performance/Modified Replies — 2 Last Post — 06-27-2010 12:47 PM
Thread — Cracked tunnel Thread Starter — rollthecoal Forum — General Snowmobiling Replies — 14 Last Post — 12-07-2008 11:51 PM
no new posts
