Ecu reflash for 18 ER&EB
Sunvang
1,043
379
83
35
Norway
How are the early builds when you start it cold? I was told it always needed 2 pulls before it started. I have a late build and it starts on first pull each time. Could that be a change in the ecu update?
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Mine was built in september, takes at least 2 pulls cold. Sometimes 2 when warm.
Mountain Cat
dboivin
436
169
Michigan
took mine in to get flashed and there was another bulletin for heat shield install. So 3 bulletins so far on this EB mc.
1. clutch replacement
2. ECU flash
3. Heat shield to protect panels
M7-Ballz 2 the Wall
118
19
18
39
Anchorage, AK
2. ECU flash
Should be the heat shield for the exhaust side abs a new side panel for the clutch side with the stiffer support added for the EB and Er's
gp800
208
205
What month would the sled have to be manufactured in to be considered an “early build” and where can you find out when your sled was built? This is my first Cat.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Early builds are spring sleds (march)
Late build is regular season (july-october)
Mountain Cat
Snow Fever
94
BC
Anyone with the new flash for the early release sleds try it out yet? seeing any difference?
Anyone know what the reflash is suppose to do?
