I've replaced the TPS and TPS pigtail and set the TPS voltage per the manual by setting baseline then increasing to .93 volts with idle set screw. I've done this a number of times but the sled still idles at 2000-2100 rpms. I even tried to decrease the idle with the set screw and was able to hold it at 1400 rpms but thought that was too low. I have been unable to get it anywhere close to 1700 rpms. I sprayed starting fluid on the pto side seal to rule out a bad crank seal...that seemed fine. Plugs look great too so I don't think I have unmetered air getting into the system.
Any ideas?
Any ideas?
