Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 12-06-2016, 08:20 PM
Reddragon800 Reddragon800 is offline
Currently: Not set.
Reddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond reputeReddragon800 has a reputation beyond repute
Default 2016 axys 163 with jaws pipe
Finally got out and tried my new jaws pipe. Overall i was very happy with the performance that the pipe produced. However, i feel that the stock computer and a heat shocked motor (128 degrees), really start to add fuel and pull timing. If there was a few minutes where we stopped and the temperatures dropped, it really made excellent power at the 110 degree temp. Im going to remove the thermostat and see how it runs next trip with temps running around that 110 area. Here's a quick edit of one of the days in Blue River.
https://youtu.be/nnl7sAGRVd8
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Reddragon800 For This Useful Post:
mountainhorse (12-06-2016), Tree Boss (12-07-2016)
  #2
Old 12-06-2016, 08:30 PM
mountainhorse's Avatar
mountainhorse mountainhorse is online now
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
Are you sure it wasn't 'hot pipe' change?? (or lack of 'hot pipe')
__________________
Signature:
  #3
Old 12-06-2016, 08:35 PM
Currently: Not set.
Default
It was always when the motor temp was above the 120 degree mark. Its hard to say if it was because of pipe temp or not. The only reading i have is a colder motor. Thats why Im going to try and remove the thermostat and see what happens. I know from a few sources that the ECU adds fuel and timing over 125 degrees.
  #4
Old 12-06-2016, 10:42 PM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
Default
Hows the power compared to the 850?
The Following User Says Thank You to goridedoo For This Useful Post:
XFIRE800 (12-07-2016)
  #5
Old 12-06-2016, 10:52 PM
himarker's Avatar
himarker himarker is offline
Currently: fixin green combines
himarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond reputehimarker has a reputation beyond repute
Default
What kind of clutching you running? Springs, weights? Elevation?
__________________
Himark Custom Fab: (509)629-0859
Custom sledhauler flatbeds
'16 AXYS 163
  #6
Old 12-07-2016, 01:12 PM
Solarguy's Avatar
Solarguy Solarguy is online now
Currently: trials213mt@gmail.com
Solarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond repute
Default
Quote:
These sleds normally run at 127-130 unless on a hard packed trail and they run much hotter even with scratchers.
  #7
Old 12-07-2016, 06:11 PM
Currently: Not set.
Default
Im running stock clutching and ride at 6600-7200 feet. I need to gear down more. 1.95 is way to high for a mountain sled. Im going to gear down to 2.39 and see how that feels. The 850 has more top end, even with the pipe on my axys. The bottom end and mid range feels very close. i think the biggest differnce is traction. The 850 with the 165 3" really hooks up. I have a 163 2.6" track and it was very noticeable how much more traction the 850 got. Track speed was close. My axys was 41-42 mph on a good climb. The 850 was 43-44 mph on the same hill.
goridedoo (12-07-2016), HPJUNKIE (12-08-2017)
  #8
Old 12-15-2016, 10:38 PM
Ihaveadragon Ihaveadragon is offline
Currently: Not set.
Basic Member
Ihaveadragon is an unknown quantity at this point
Default
My 163 runs around 130....couple buddys run the same for temp too. Pretty sure thats the norm
  #9
Old 12-16-2016, 09:37 AM
Killer Time Racing's Avatar
Killer Time Racing Killer Time Racing is online now
Currently: Need more current , to get current
Killer Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond reputeKiller Time Racing has a reputation beyond repute
Default
127 was as low as I've seen ... Saw 148 on a packed road and never have deployed scratchers ..17' 155 Assault
Had a Comp Track on for trail riding and got a last minute trip to Afton so had to run the Slick and threw some 60s in it and jumped in the truck
Definitely a trencher but hey I got 7 of my 18 hours done
  #10
Old 12-08-2017, 06:41 PM
whitejeepxj whitejeepxj is online now
Currently: Not set.
whitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond reputewhitejeepxj has a reputation beyond repute
Default
How did removing the t stat work out for you?
__________________
2016 SKS 800
Favorite riding spot - chic chocs!
  #11
Old 12-10-2017, 12:47 AM
snobyrd snobyrd is online now
Currently: in memory of Johnny,JAN 23 2011
snobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond repute
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 Axys Rmk 163 - Video Thread Starter — Reddragon800 Forum — Polaris: AXYS Replies — 4 Last Post — 05-11-2016 08:19 AM
Thread — Looking for a 2016 Axys 163 Thread Starter — smokenjay Forum — Polaris (Swapmeet) Replies — 4 Last Post — 03-20-2016 09:46 PM
Thread — WTB: 2016 AXYS 163 Thread Starter — Kounkel Forum — Polaris (Swapmeet) Replies — 1 Last Post — 12-29-2015 09:35 PM
Thread — Looking to buy a 2016 163 Axys Thread Starter — Ace Freely Forum — Polaris: AXYS Replies — 20 Last Post — 10-24-2015 11:51 AM
no new posts
