Been running IS kit for a long time and a similar kit before that. 1300 miles and counting right now on the same belt.
Anyone got a clue what Indy recommends for belt-to-sheave clearence? Cant find any info regarding it on their homepage for their Turbo clutch kit (v3 weights).
That high boost clutch kit could be interesting for me! Going to lower CR to ~11;1 and increase boost to around 15psi.
Just completed the Heavier Turbo 3 weights.
Identify - HT3
They are 4 hole tune able... Base weight 68 grams and Full weight
they are 82 grams
Also made a header pulling Helix, and a new spring for guys that really ride hard and build more heat then average riders do, holds the belt a little better in extreme conditions.
Dan
are they the same profile as the t3s? other than the extra hole {added adjustment} what could a guy expect to see/feel between the 2. I am completely happy with the last kit you put out...my clutch temps are a little hotter than some are but not hot. 500miles on my belt and its still looking good!
