V
OK, 04 800 summit rev, 162 x 2 1/4" maverick. Stock motor w/brand new vf3's. New top end w/600 miles on it. Pistons look good. 390 mains, 20 pilots. clip 2nd down from top w/shim under. Carbs cleaned last week (did not blow out jets, stupid) tips on how to blow out jets would be appreciated to.
Put a Big John clutch kit on this fall. New spring tower cap in primary also.
Sled pulled decent from bottom to 3/4 throttle. Once on the main jet it rips up till it hits 7800-8000 then the tach starts to bounce around between 7700-8000. Feels like a small child is hanging on to bumper (stole that line )
Can't get higher revs. Tried raising clickers from 3 to 5. no difference... still bouncing between 7700-8000 rpm's.
Removed pin weight, set clickers back to 3 and tried agian. no difference.... dropped clicker (just to see) to 1..no difference
Took it 2 wks ago to Turbo Al, he took a quick look at it. Al installed his clutch spring combo (primary and secondary) as well as installed his pin weight recommendation. He said I had the right helix in in so no need to change it. I didn't doubt BJ's setup, just desperate at this point.
Took it out Wednesday in 20" fresh snow. SAME THING????? Clickers make no difference.
Don't think its DPM related as we just rode Sicamous for 3 days in serious frost bite temps without problems.
My green horn thoughts: must be rave related? Just cleaned raves 2 wks ago ..
wtf going on here?
Help
wtf going on here?
Help
