Ever see a Power Valve make contact with a piston?...I have :(
M
108
On my 2009 M8 with 420 miles I noticed after riding for 2 days the coolant level was down to the bottom of the coolant bottle.
So tonight I did a PSI test on the coolant system. And found coolant seeping out where the head meets the cyclinder. So while pulling the head bolts I noticed where it was leaking the head bolts were just more than finger tight (Thanks Cat). But I decided to pull the head instead of just tighting the head bolts, and order new O-Rings. And to make sure the coolant didn't make it into the cyclinder...which it didn't.
While I had the head off, I was looking at the piston. And on the exhaust side cyclinder (were the head bolts were loose and leaking coolant) looks like cornor of one side of the the power valve made contact with the piston. It doesn't look like it harmed the rings, but the piston has some marks on it.
Now I am wondering why the power valve made contact with the piston??? And If I am needing a new piston and rings?
I have pics but do not know how to post them. If somebody would, PM me there E-Mail and I can send the pics for them to post.
M
108
Also is there a trick to getting the coolant hose off and on the back of the head? I have the head unbolted, but it looks like the rear coolant hose is a PITA to get off and an ever bigger PITA to get back on again
KSH
Steering Wheel Holder
3,774
1,857
Larkspur, CO
M
108
In the second pic where the screwdriver is. The edge of the piston is not a smooth radius, it is sharp edge and pushed inward slightly. But didn;t turn out in the pic
Thanks for posting the pic KSH!!
J
JasonAK
759
134
I had the same thing happen to my M8. If it is under warrenty make them fix it.
I thought I was the only one, only happened on one jug the PTO side. I had to grind down the power valve to clear piston.
Jason
M
108
No warrenty
Is there anyway the power valve is out of adjustment, and that is what caused this? I wouldn't think that it should be able to ever make contact, weather the adjustment is out or not.
So I need to grind the power valve? Think I need to replace the piston/rings? I think am going to try to get one more trip out of it. Then I will be done sledding for the year, and I can put a new top end on it this summer.
AaronBND
1,696
449
83
Cascade Mnts, OR.
No warrenty
The adjustment is only for them opening, not sitting where they are suppose to in the cylinder. Sorry, but that's fu*ked up on a new sled! I can see it on a bored jug where a guy forgot to grind them shorter, but on a brand new sled from the factory?
Aaron
gopher-it!
324
76
nick
No warrenty
this has happened twice to kids m8, warranty both times, it is were the power valve sits in the cyinder, new cylinder last time.09 m8.
skibreeze
10,463
3,477
Colorado Springs
I had the same thing happen to my D8. Looking at my pv's, you could see that they actually curled inward at the tip. I'm guessing that it was from the extreme heat softening the tips. I also just ground them down to clear the piston.
9
Dec 22, 2007
100
24
18
Yours doesnt look like it was hitting as bad as JasonAK's. Looks to me like it was just enough to push the rings in and mark the pistion. probably just a couple of thousandths.
If it comps out the same on each side and the rings have no visable damage. I would'nt mess tearing it down. Just file the tips of the valve back to business..
On JasonAK's sled there was a good amount of ring damage.
