Same motor new crank. Before the crank went I put in a almost solid mount on the bottom mag side and was hitting 7860rpm at 7000ft, Before I was only getting 7400 ish rpm. But the mount was to stiff, real bad vibration in foot well, so I installed this. There is a slight bit of vibration in the foot wells but not bad. I have had clutching issues for a while, my rpm would climb to 7500 and then drop, once it was dropping down to 7000rpm. I also went back to the stock intake, to me its not making the power as it was before and I will probably put the aftermarket intake back on. But for the first time I'm hitting rpm with a 060.
THE 046 IS HARDER AND SLIPS. THE 060 IS SOFTER AND WILL USUALLY DROP THE RPM 2-300
If you think about it the mag side has 1 1/2 mounts when the pto side has 3 mounts and a rubber stop. I could see the mount on the mag side had been digging into itself(moving a 1/4").
