<iframe width="560" height="315" src="https://www.youtube.com/embed/lwB9sXl_0iA" frameborder="0" allowfullscreen></iframe>
Thanks for the vid.
How do you deal with the back Mount holes being halve ways on the heat exchanger and halve of underneath the tunnel ?
I see on the front they have factory cut outs there.
Yes but if you drill them the hole will come out right on top of the seam between the cooler section and the outer tunnel .
This gives the nut insert only halve the surface and it has a 1/16 gap on the outside. the frond Link mounting areas have the inner tunnel sheet cut out but the back ones for the ski rack do not.
Be careful lifting your sled when it is stuck with this new hd bumper. It is cast internally, and is as fragile as the bulkheads. Buddy down the street has it installed in order to add the snowboard rack. It broke in his hands on the first real pull when the sled got stuck.
front and the better shot is the back where I had to cut it out
Those would be good pointers.
That is on a 154 and drilled dead on the marks up top everything fits as designed after this .
