M-1000 Bad Injector?
L
longtracksedge
New member
Dec 6, 2007
81
4
8
2007 M-1000 flashing code that says malfunctioning injector? This is not my sled, only trying to help a guy out, but are the injectors easy to pull out and clean or replace? Anyone else ever have this problem. It ran fine for two days, then on the third this problem arose. Starts fine, just no upper rpm power....
L
longtracksedge
New member
Dec 6, 2007
81
4
8
The guy took it to a dealer today. Said that was only running on 1 cyl, and it must be some kind of "ground" issue. Said snow can get packed in behind the motor somehow???? Anyone else ever seen or heard of this? This then can cause wires to rub on back of motor?
Truckee Coastie
97
29
18
Truckee, CA
Is he running a BD box? Buddy had the same code, and it was a wire grounding out from the Boondocker fuel controller. Check his wiring behind the coils goiong under the fuel tank and the wiring at the tail light. The tail light was more an 09 issue but check it, its reall easy to see under there. Good luck.
