M
i have an 05 m7 and im trying to decide if i want to spend the money to rkt kits that is said to fix the problems that im having. does anyone run this kit and if so how much does it help? thanks
I just ordered one to try myself. Spent quite a bit of time with him on the phone and he said the stock secondary is "mechanically broken". I don't really understand that because of how simple of a task it has. Basically a spring pushing rollers up a ramp to me. He says it does not shift out all the way. I don't know if it's the orange spring or the helix or what. I will try it, and if I don't like it's results have one for sale. If I like it, I will stand behind what he says and promote it for him.
Aaron
Tested my new RKT secondary on my 1000 today. Mixed results but I'm going to call Kelsey. The sheaves would open and stay open (like you were loading a belt) and I would lose all belt tension. I'd have to physically remove the belt to get the clutch to close and then I'd have to re-mount the belt. Happened twice in deep champagne. Mo-Flow side vents seems to let the extremely fine snow in... but I don't see how it would effect this clutch in that way.
Rush44, let us know what you find out, please.
Same kind of thing happened to me I think, took it apart and reassembled and worked fine. I think it's easy to not put enough preload on the spring, make sure you index the spring and cover with enough tension.Tested my new RKT secondary on my 1000 today. Mixed results but I'm going to call Kelsey. The sheaves would open and stay open (like you were loading a belt) and I would lose all belt tension. I'd have to physically remove the belt to get the clutch to close and then I'd have to re-mount the belt. Happened twice in deep champagne. Mo-Flow side vents seems to let the extremely fine snow in... but I don't see how it would effect this clutch in that way.
sounds good bosscat! hope to hear good word because i want my sled ripping perfectly. @rush do you think it was worth the money?
When are you going to be able to test the new clutch on the snow ?
Been thinking about his set-up myself, but been dragging my feet.
