318 miles (10.4 hours), 70 miles today, 8.8 gallon fuel (7.95 MPG), 33 oz oil (ratio 34:1).
It was an interesting ride today. 6-14" of new on top of 12". What I'm going to say will please the Doo loyal. I wasn't too impressed with the sled until today. The motor opened up a little bit more today, and the power is actually pretty good for a stock sled. The clutching is still kinda funky, but this clutch and motor wants a load. In less than 8" of snow the clutches want to shift out(reverse helix?) at around 58-62 mph, dropping the rpm to 7900 on clicker 4. However, get into deeper snow and the clutches stay loaded and it will hold 8100 no problem. I did one run up the road, I would say 7-9% grade, 14" of new, wide open 8100 @ 64-65 MPH. Which I think is pretty respectable. Gives me some hope for maybe close to 50 mph in a climb.
With the tool kit holder in place my clutches got so hot I could begin to see the glue coming out at the thread the last ride. The tool kit holder blocks probably 85% of the airflow from the front vents down thru the footwell. I removed the tool holder and today the clutches were cooler, still hot but not destroying the belt like before. I will ride it like this until the belt wears out or fails, so I have something to compare too. If the belt will last 1200+ miles like my 08 I won't vent it, if it fails sooner than that I will have to look at the XYZ, then maybe vent it.
The ski's push more than I like, what works the best so far is more ski shock preload(3), and adjust the center shock until it turns the best. These new ski's really spray up into your face at slower speeds sitting, not so bad once they get up on plane though. Sitting riders be prepared for a real snow shower, even worse in the turns.
I only think the new 36" front end and longer center shock improve the maneuverability by 10-20%, however today demonstrated just how useful that little extra can be. Riding the ridge road at 8000' the visibility was abysmal, no check that, it would have been a step up to abysmal today. Snowing hard, 40 knot winds, foggy, lens fogging, and flat light. The drifts were 2-7' deep, deep undulating rollers, in truth way more than I wanted to bite off for an early ride, but once in it I stuck with it. 3 miles of continuous rollers, no break at all. I was gasping for air at the pass. The sled really showed me something today, didn't get stuck once, and I'm pretty sure I would have several times on the 08. This sled really gets up on top, can't say if it's the non-ported track or suspension, but I had to go much slower than I wanted because I couldn't fraking see hardly anything, but the sled just kept plugging along thru continuous 4-6' soft drifts. The agility and the track really performed well today! Man was I ever glad to have my tracks to follow back out as the wind picked up even worse, colder than frak! Gloves were frozen solid, helmet strap so frozen could not get my helmet off.
I still have the anti-freeze leak, but finally got the flashlight in the right spot and can see it's the oeticker clamp on the front big hose, brp replaced 2 of the three with regular hose clamps but left one oeticker on, and it's leaking. I stopped at the dealer to schedule a drop off tomorrow after my ride.
If we get the 12" the weather guessers are predicting tonight I will go to my little honey hole for a little climbing tomorrow for the first time and see what kind of track speed I get. I distinctly remember what I was getting on the 08(around 45 mph) last fall in pretty much the same snow depth I can expect tomorrow. Not a direct comparison, but if I see close to 50 I will be pretty satisfied.
The new dual air intake is an improvement, but busting through those deep drifts I found out it will still plug up and bog. The snow sits on the side panel ledges and blocks the intakes, they still ice up too. An improvement, but as I feared not the solution.
