There is not a kit like that available. The individuals who had this set up, done it themselves. It is all custom work. But I will tell you they work very well. Much better than a water to air, because you do not need a pump to pump the coolant. I believe at one time or another, MCX had a cooler under the tunnel, and then the charge tube went from there up to the main air to air in the front of the sled. But the cooler that was mounted under the tunnel had constant snow hitting it, and it did not need any coolant flowing through it. It was the heat exchanger, and intercooler. and it can be as big as the heat exchanger at the front of the sled. (Lengeth and Width). It may need to be thicker/deeper to flow more air. but with constant snow hitting it, it is always cool. With a W to A, it has to pump, and at some point, it the coolant will warm up to a certain constant degree because of the flow speed of the pump. The air to air is as cool as the snow out side, no heat soaking nothing. It just needs to be mounted where the snow can hit it.
