thanks for all the comments, gonna have to wait a few more days to try some of these techniques, cause theres a couple feet of fresh in the hills!!!!
The powerclaw sucks going downhill in any kind of snow. If you ride in an area with lots of run out or a little less angle in the hill, then it is okay. If you ride steep slopes with trees at the bottom you better be aware of this or you`ll be in trouble.
To say that you need to pulse the brake and shake side to side ( ya, I do it too and everything else) proves it.
If you have ever riden side by side with the same sled with a camo extreme or even the wimpy old camo 2 in. we used to get it would be so obvious you would be envious of the alternate lines available in a downward path.
If you`re a bit intimidated going down a long hill with the powerclaw, it`s okay because it does suck on braking. Anyone who says its good is not being 100% truthful or doesn`t ride the same terrian.
Rider skill can make up for anything, but should it be that way.
Geo
couldnt disagree more my friend, i was doing everything in my power to slow down, from going side to side, to featherthing, to engage, feather engage, feather etc. the reason i know the powerclaws are really bad is that the xp i almost REAR-ENDED was having no issues slowing down all day, on anything. i just about rear ended him a few times that day. would leave myself lots of room between each other and by the time the bottom came i was looking at ways to get passed him. and this isnt my first rodeo either by the way.
So what do you consider the proper tension? Thanks.I have the PC HCR track...(thanks Kinz)...
This track is very sensitive to track tension... if you believe the wives tales of a loose track gives you more performance... then it WILL suck going down hill. (a loose track will not go up hill as well either)
The PC is definitely not the best in downhill situations... but running the Proper tension on this track makes a difference.... same sled, same day same hill... loose compared to proper tension... the proper tension wins every-time ... according to Camoplast... the paddles load up and lay down more if the track is run loose which is what gives you the "magic carpet ride" downhill so badly...
Will proper tension on the PC give you "CExt performance" downhill... IMO... NO... but it will make it better.
My 2 cents.
Yeah, The Camo Extreme 2.5" kicks azz!
And the Skidoo Powder Max 2.25" does almost as good.
to heck with turning it around just lock the brake then hit reverse, then easy as she goes
Start making a quick habit of doing that to your DD and then this thread will be full of comments of how pissed off people are of their now "broken" DD. Then people will chime in saying how the DD is a piece of $hi#. Blah blah blah.
IMO......don't treat you DD that way. You'll be sorry quickly, I promise you that.
