850 thermo bottle
TRS
Life Member
4,118
6,275
Cody, WY
Mocking up the thermo on my ‘12 turbo. Don’t see why it won’t work on a ‘16-‘19 800 AXYS
attachment.php
attachment.php
DFFB7010-F0E7-4EC5-B537-92000318450A.jpeg 7CE00BD9-9891-46CB-8305-2AB6271E6CAD.jpeg
Bushwacker1
297
183
Wisconsin
Nice! Im actually doing the exact same thing on my -13's 137" pro-rmk build.
Got my bottle yday.
137" ?
I have so many questions on skid choice and other details. So as not to hyjack this thread i ask Please please please start a build thread and share the details with us.
Norway
1,978
476
83
49
Nice.
Do you need more parts other than the bottle itself? Many Things that must be changed/modified to tie it inn? Mounting etc.
TRS
Life Member
4,118
6,275
Cody, WY
Yes, a bracket needed to be built to hold the bottle. I splurged and bought the 850 hose from the bottle to the pump. I had to cut it? to make it work. I have a large assortment of hose bends to complete it, that part was easy. The added center cooler created fuel tank clearance issues that you won’t encounter with stock cooling. Heating the tank with a heat gun to made more clearance. Hope this helps.
TRS
Life Member
4,118
6,275
Cody, WY
did you ride your setup yet Tony?
No.
Just headed to get my complete exhaust system and turbo. I had them Cerakoted by a local shop.
New electrical connectors are in order also. Upgrading the Boondocker plugs and shortening the 5 miles of wire.?
Norway
1,978
476
83
49
5 miles, LOL! Yeah, such things are nice to snug up and organize.
See the bottle is $44 With Babbits, so if you are a DIY person with tools and a tiny bit of leftover parts, this will be a cheap coolant temp fix! Bottle cap is the same.
Nice little mod Tony.
Bushwacker1
297
183
Wisconsin
Tony
Hard to see but I think there are 4 large hoses plumbing to this bottle with only one below the t stat? Looks like all return water (cooler water or bypass water) goes back thru the same hose to the pump. Trying to see the flow thru it and how the bypass for warm up is but I keep imagining an easy path back to the pump creating a short circuit not allowing full flow to the coolers when the stat is open. Is there another chamber inside the bottle above the t stat with a small bypass orifice that will only allow a small flow when the t stat is closed and bypassing? Tried to look at this on the parts blow up on line but Polaris only has part numbers and no diagram. Can you clarify to help me see the flow path?
TRS
Life Member
4,118
6,275
Cody, WY
Tony
Coolant goes in the bottle at the thermostat, with the thermostat closed it directs the coolant into the bottle and back to the pump.
When the thermostat opens it closes off the path to the bottle and sends coolant through the tunnel and back to the bottle. Does that help?
Bushwacker1
297
183
Wisconsin
Yes that helps. From the pictures I saw the coolant hose coming from the engine with flow into the bottle and it looks to be above the stat. Also saw the output from the bottle for the cooler input coming from below the stat which made sense. Just could not see how the stat was closing off the bypass flow when the stat opened from the pictures. This looks like it will clean up the engine bay with the bypass taking place inside the bottle and sharing the return line to the pump. The Polaris diagrams I checked on line for 2019 800 engines do not seem to have this new bottle. The one diagram that Polaris has on line for an 850 Indy 129 shows more hoses going to this bottle and it looks like they may be running the front cooler and the tunnel cooler in parallel instead of in series.
Thanks for the clarification.
TRS
Life Member
4,118
6,275
Cody, WY
Just north of $100. That doesn’t include power grip clamps, hose bends that I had, or the 1” nylon hose conectors.
Norway
1,978
476
83
49
Hm. It LOOKS like all you'd need is the bottle?? Modify the hose going from the head to the coolers (cut away center piece) so that it can og into the bottle and out the back. Require more length perhaps? 2016 Axys RMK mind!
TRS
Life Member
4,118
6,275
Cody, WY
The 850 hose was an added purchase. The bottle has an up size port.
beamslayer
944
314
Thanks Tony as always you are on the cutting edge . I was wondering how this turned out sure would rather spend $100 to cool my sled . I did the Doo stat on my 11 worked great .
TRS
Life Member
4,118
6,275
Cody, WY
Haven’t had it on the snow. Looks like it will work well.
Kids and Grandkids are here for the holidays. We went back to hunting��
Not a lot of snow here. It’s surely “dealer snow”.
