BDX ASCENDER PRO BOARDS IN STOCK!! ON SALE FOR ONLY $299.95
BD-Xtreme
267
NEW INTRODUCTORY PRICE! ONLY $299.95 PER SET!! NORMALLY $349.95
Our new ASCENDER PRO-BOARDS are the best running board on the market for your machine, and here is why.
-No snow will build up on top of them. The extrusions round and triangular shaped to prevent snow build up, the snow simply falls through the openings. We have also increased how for open it is by the footwell compared to the previous design.
The triangular shaped extrusion fits nice and flush against the tunnel so that snow can't build up along the tunnel like a tube will. We improved the design so that you can rivet them on from the bottom instead of the backside, which makes installation time much easier and less time.
We also improved the rear of the boards so that the triangular shaped extrusion which is riveted to the tunnel has traction teeth build right into it, and the snow will not build up on it.
The welds are top notch.
-Built in non slip traction teeth incorporated into the extrusions. (no need to screw in the traction screws like the competitions, which can come loose and fall out)
-Strengthens the chassis, less flex. Our new inner extrusion allows for easier installation and extra strength.
-Available in a variety of colors. Black, Lime Green, Green, Orange, and White. Also available natural aluminum.
They fit all 2018 Arctic Cat mountain sleds, 2017 Mountain Cat, and 2017-2018 M9000's. Also Yamaha MTX Sidewinders 2017-2018.
These can be used in conjunction with our ProMax Induction Hood if you are updating your 2012-2017 Model.
http://www.bd-xtreme.com/index.php?id_product=744&controller=product
2018 ascender pro boards updated.jpg ascender running boards colors.jpg welds 3.jpg
Sunvang
1,043
379
83
35
Norway
Received mine yesterday. Looks very good, but sadly they were in the wrong color.
X
Jan 27, 2008
259
44
Minnesota
I put a set on my '12 with plans to swap out the plastics. I'm a fan, they work as advertised. Straight forward install. Takes a while to get used to a flat board tho.
