I
If pol doesn't paint the tunnels on the new slee they are makng a huge error
Hydrophobic and iceophobic are separate issues.. but have you actually used a normal HIGH GLOSS spray paint under your tunnel?.
I have done a bit of research on the subject myself. . I.found a lot aboit it i. Use for electric power lines.. when they get ice built up on them they snap and customers lose power/electricity. .. was not a ton of options
Yes have tried high gloss clear spray paint too. Nothing I've tried works like powder coat
I've got to agree. I just sit back and take a break while all the Poos, Doos, and pre-14 Cats are de-icing...
Does anybody remember or know how much weight difference there was in the Suzuki 600 to the Cat DI 600? Just wondering if the Cat DI 800 will weigh more or less than the Suzuki 800.
....That Suzuki built 800 engine is 18 pounds heavier than the Polaris 800. Add in the three pound heavier drive clutch which is weighted to properly balance the heavier crank in the Arctic Cat and 21 pounds of the difference in the two sleds is found in just the engines. Seven pounds more of the difference in the two sleds is in the exhaust silencers. Just swapping engines and exhaust would leave the Pro Climb lighter than a standard RMK by a fair amount, and maybe a bit lighter than a Pro RMK.
<!-- / message -->
This is the statement that the guy had about the weights of the motors....QUOTE]
Cat Spec sheet on my '14, 162 PC showed 470 lbs so it will take more than 28 lbs to get to the 435 of a standard RMK. To remain competitive, Cat definitely would benefit from a cleaner motor with better mpg, maybe a little hp and less weight would be great. Combined with a few other chassis mods, exhaust mods, and maybe a belt drive and cat could shed the weight of the "heavy sled" problem that drags down sales regardless of performance. I can't imagine why they wouldn't at least set a goal to be within 20 lbs or so of the lightest competitor and then sell the idea they have a more durable, but almost as light sled. If they're within 20 lbs who is going to care. It's the current +40 lbs that's a problem. My guess is you'll see most of this by '17, but not likely this year...been wrong before.
I find it very very hard to believe there is that much weight difference between the Cat 800 and Polaris 800 just in the engine alone. That to be 25%. Seems impossible.
