Well Ive had a few PM's about the mounts I built so here's the deal.
I used two 60 duro mounts up front, Part# 0608-404 and I used two 50 duros in the back, Part# 0608-405 (One replaces the Mag side mount and the other replaces the TCL). The mount on the TCL needs to be machined to allow the bolt to be counter sunk into it and also for the proper thickness.You also need to take some measurements to make sure it is pressed into the TCL the proper distance so you wont effect alignment.
Now on the front mounts I used 2.5 by 3/8 flat bar aluminum, (in retrospect its a little on the beefy side) Then you just need to machine a 2" hole to hold the rubber mount, they are interference fit and the easiest way to put them together is to put the mount in the freezer and the aluminum in the oven at 300, then if your fast they will slide right in. To mount these to the motor you can either fab up something out of angle aluminum or buy the front mounts off of the M8's Part# 0608-549.
This makes a huge difference in how much movement there is (its now comparable to my m1000 with extra mounts) but it does transmit a lot more vibration at idle. I dont have any definitive answers as to how it effected belt life b/c of some motor trouble on the last trip, belt temps are still very high and I did pull some cords on one belt, but it was in rough shape before hand.
