D
i agree with going west i would never be happy with a string hanging off the belt ,if i had no spare i would have to take it easy , who wants that
After the first trip to BC we are down 3 belts between two sleds (Cords hanging out, not totally blown). Only about 120 miles total over 3 days.
Getting the same BS response form dealer about not properly breaking the belts in, even though the first belt I lost was washed, scuffed and had a 18 mile break in. There was no heavy continuous riding that would have even got the clutches hot.
The alinement has been checked again and is correct according to cat, and I checked the secondary for the jack shaft play, its fine. I found a solid black ring of rubber about 3/4" wide at the bottom of the primary at the end of the last day. This and the fact that the defection changed a lot very quickly leads me to think that the side clearance on the primary is not set properly.
We were also experiencing a lot of belt chatter as we were riding tight trees and where in and out of the throttle all the time. Could this also be a result of improper clearances.
Is anyone else experiencing this. I would really like to get this sorted out before the spool goes on so any help would be great.
Did you fix the vents or just get on it and ride?
Not 100% on what you mean by fix the vents. But I did have frog screen over the fan intake vent on the clutch side, and my panel was installed properly. I never really noticed any obvious belt slip due to snow. I have not done anything with the rear facing vertical vent .
