Upgrade to Premium
Performance/Modified Discuss modifications for your sled
  #1
Old 02-22-2010, 10:44 AM
Rowdy1132 Rowdy1132 is offline
Currently: Not set.
Basic Member
Rowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enoughRowdy1132 will become famous soon enough
Default 809 misses after 1/4 throttle. Please help
Just started missing saturday, idles fine on all 3 cylinders, as soon as you go past 1/4 throttle starts missing, and egt is about 100 degrees cooler on middle cylinder, plug is alittle wet. Tried switching plug wires still middle cylinder wet. Checked power valves, they're ok. Gonna check reeds tonight, really stumped, any help i'd appreciate...thanks
Rate this post: Yes | No
  #2
Old 02-22-2010, 05:14 PM
joshkoltes's Avatar
joshkoltes joshkoltes is offline
Currently: TOO MANY PROJECTS!
joshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond repute
Garage
Default carbs
i had a jet fall out once, kind of acted that way
__________________
Snow
  #3
Old 02-22-2010, 07:17 PM
treetopflyer's Avatar
treetopflyer treetopflyer is online now
Currently: lovin boost
treetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond reputetreetopflyer has a reputation beyond repute
Default
Round slides or flat
  #4
Old 02-23-2010, 10:42 AM
Currently: Not set.
Basic Member
Default
They are flatslides rack. I'm thinking it's the fuel pump, reeds look good. Jets are good, carbs good, compression good.
  #5
Old 02-23-2010, 03:26 PM
Hardass's Avatar
Hardass Hardass is online now
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
a stater going bad will do that.
  #6
Old 02-24-2010, 09:31 AM
Currently: Not set.
Basic Member
Default
Not the fuel pump, gona try stator next. What a pain. thanks guys
  #7
Old 03-02-2010, 01:53 AM
likinit2 likinit2 is offline
Currently: Not set.
likinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant futurelikinit2 has a brilliant future
Default
Check to make sure the slides in the carbs don't have the corners broke out. I had an XCR8 do this and that was the problem. May or may not apply but an easy check.
  #8
Old 03-02-2010, 10:10 PM
4GR8X 4GR8X is offline
Currently: Not set.
4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute4GR8X has a reputation beyond repute
Default
Greetings Rowdy 1132,
Consider replacing the center plug if not all three.
Good luck.
Craig.
  #9
Old 03-03-2010, 08:15 AM
Currently: Not set.
Basic Member
Default
It was the stator, thanks for the help,.....
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
