T
i am trying to test my system using a coolant leak tester. I blocked off the exaust pipe with a plate and gasket and my coolant tester adapter fit nicley into the charge tube inlet almost a perfectly, then I clamped it in tight.
I cant get more than 5 psi pressure through the system and I do hear a small leak under the thottle bodies. Its the worlds smallest leak, but you can hear it fainlty.
Is a leak this small a problem? I was seeing boost spikes up to 17, but I also had an exaust gasket leak which I fixed.
Should I be investigating this further? Should the system pressure up to 10-15#'s with a coolant tester?
