I Talked to Carls Cycle today,
The angle on the sheaves is the same angle cut they have been doing for years and I have run on my Pro sleds for years.
Here is a post from Carls Cycle: FWIW..
Carls Cycle
03-26-2015, 09:25 PM
The new belt is a better more durable compound, and will fit on the older model pro's. The new part number by the way will be 3211183 if anyone is interested. The 2016 also has a new Primary that has sheaves that are cut to match the belt angle better (exactly like the clutch mod that we developed here at Carl's), as well as helping to reduce belt heat. The belt will retail for 199.99 to the best of my knowledge, though prices may change as usual.
S/C
This is what I was saying yes its a more durable compound but they are not sure on the performance level side of things. My pro's with Carls cycle clutching and sheaves cut were never hard on belts before.
The cut that Carls cycle had on there sheaves were the angle to the proper belt for the pros 11-15. Stock the pros came with a multi angles primary sheaves. (one angle lower in the sheaves and one higher in the sheaves)
My assumptions are but I did not ask exactly but if they were cutting the sheaves to the previous belt angle properly then this belt angle should not have changed but the primary sheaves changed.
I can tell you on the 2015-16 short track Rush sleds the belt is harder, more durable, doesnt blow up but it will loose alot performance as it wears in compared to the previous shorty rush sleds of 2011-14.
This has been the trend on the RZR's also. They come out with a new belt compound every year it seems, now they have gotten so they wont blow up but they loose alot of rpm as they wear. For performance wise Carls will tell you the best belt to use is the 2014 belt for the rzr 1000's
