After spending more time than necessary to install the Trail Tank I feel obligated to advise others about this product. Its a PITA for lack of something more sinister to say, and if I'd known it was this much trouble I would not have put it on. The fit sucks! To the extent in fact, that I finally chopped off the existing tank bolts and am installing threaded inserts into new holes for it to fit. When even the instructions tell you to "pry" the bolts into the new Trail Tank holes, I think it's telling you its not molded properly.
As well, because the tank does not fit properly for those bolt holes, chances are that you seat will also not fit in the existing holes on the heat shield, as I had to also change this. If thats not bad enough, then the front panels also don't fit properly, so the holes have to be drilled out so the new screws that hold them to the tank can fit! Oh, and did I mention that the fuel hose to the tank should be changed as well because it is so tight I can see the plastic fitting snapping off! FYI, this isn't just me, my other 2 buddies also had the same problems with their Trail Tanks and, the Yammy dealer we bought them from also said they've had nothing but problems!
One last thing, if all the above isn't bad enough, they only hold 37 L and not the 39 L they advertise! I contacted the company about this and they remarked that they had to "remold" the tanks for the coolant hoses so lost some of the capactity, and that they "should" update their site. That was last season and it still hasn't changed. I'm guessing you know my opinion as to whether or not to buy the tank! Carry a jug...... Sherm
