8t drivers in a 16 ltd
otist
94
8
8
46
I know I've asked about this before. But I don't want to cut up my sled, so I'm thinking about just trying to stuff 8 t drivers under it. But from what I can tell I'll only have 1/4"-1/2" of clearance to the cooler. So before I spend $250. I wanna ask those of you who have done it... Any regrets?
WY_Covert
New member
37
4
8
Wyoming
Haven't done it but I have drivers on shaft $125.00 plus shipping. If you need some.
Sent from my SAMSUNG-SM-G930A using Tapatalk
knh208
317
101
Saskatoon, SK, CANADA
It works, but not as well as the Mountain Cat. It was okay to put in, but brutal to take apart after.
Sent from my SM-G930W8 using Tapatalk
kiliki
13,213
2,398
Nampa, Idaho
I put a few 3" on 8t drives on 16 sno pros, tight but fits. just like above you can find used ones for 100-150 price range.
kidwoo
2,630
1,875
It fits and is absolutely worth doing. It really lets those sleds stretch their legs finally. Just gearing up doesn't do it IMO. Stock gears, 8t only. Your entire drive train will work better.
I had the same mindset last year, didn't want to cut up my tunnel. It's a very noticeable improvement just doing the bigger drivers and nothing else.
Woody67
1,437
682
Bellingham, WA
I asked one of the Cat engineers about this when the 3" Powerclaw came out and he said "you can probably get it in there...getting it out will be another story"
knh208
317
101
Yup. I put mine together solo. It took two of us more fighting than we wanted to get it out. We were pretty upset with it by the time it was on the floor.
F7arcticcat
75
I took a small tin sign that was about 14 x 20 And wrapped it between the track and drivers, after that I was able to give the drivers a good kick yo get them out.
jcropper
61
35
18
59
Battle Ground WA
Defiantly worth doing ! Sled responds much better off the bottom, better snap to get the ski's up when need it.
plus it makes it an animal in deep, just feels like a tractor and makes you feel totally confident that you can go any where
kidwoo
2,630
1,875
I managed to get them in (and out when I dropped the case) by myself.
In both cases, I got a milk crate and held up the upper part of the track using some tie down straps. It at least gets the track pressed up against the inside of the tunnel to keep it from wrapping around the drivers. That with some soapy water and you should be able to get them IN okay.
Just make sure you don't ever trash your track so you need to undo it. But if you do, I did the milk crate in the back, and then rolled the track forward with some aluminum bar stock in the windows so that it forces the track up off the drivers.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
To install, It took less than 10min by myself no special tricks. Taking out...... whole nutha story!
Hope i don't need to.
Mountain Cat
