I have a 2005 polaris 900 fusion and reverse doesn't work and the dash lights flicker of and on and speed hand read 120 at idle
My 2005 polaris fusion will start up and sometimes idle but then it stalls and I cant start it until the next day or two. And if I ride it and stop it will stall.Reverse and dash light issue is improper TPS setting.
Incorrect speedo reading is either from dirty speed sensor below secondary clutch. Remove 10mm bolt and pull sensor and clean. Then squirt grease in zerk..and/or the speedo sensor is bad.
Would that affect it even if the electric start wont worklikely the stator
