Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 10-12-2017, 09:25 PM
RanOutofTalent RanOutofTalent is offline
Currently: Wondering what your can sounds like
RanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond reputeRanOutofTalent has a reputation beyond repute
Default Tunnel bag tools
I have a 17 163. I have never carried much for tools but recently mounted a pelican case to my tunnel and have plenty of extra room. I believe I should be carrying some select tools. Looking for recommendations on what I should have with me.
__________________
2017 Axys 163 2.6
Rate this post: Yes | No
  #2
Old 10-13-2017, 07:37 AM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
I use to bring all kinds of crap along with me. I have dialed it way back over the years. My tool kit now fits in a bag about the size of a normal shaving / overnight bag (5x8x2).
I have a ratcheting screw driver with the bits stored in the handle, including the common torx sizes.
3/8 ratchet, with one extension, and about 7-8 sockets.
Set of small common size wrenches.
Extending mirror, and extending magnet.
Multi Tool
Zip ties (GOOD, cold weather)
Some folded up rags to clean your hands with
Thats It!
The best thing you can do is go over your sled and just see what you would need to do things like adjust your track tension, tighten a loose shock or suspension mounting bolt, adjust the Toe-in, tight a ski bolt, tighten your handle bars. Just common stuff that might come loose and would be a quick easy fix if you had the correct tools with you.
The Following User Says Thank You to SRXSRULE For This Useful Post:
RanOutofTalent (10-13-2017)
  #3
Old 10-13-2017, 08:07 AM
volcano buster volcano buster is offline
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
I also have a cheap T handle exhaust spring puller from Harbor Freight. It is nice to be able to remove the pipe for access to something else.
  #4
Old 10-13-2017, 08:13 AM
Timbre's Avatar
Timbre Timbre is offline
Currently: Let 'er SNOW!!
Timbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond repute
Default
A small, yet relatively complete kit with basic tools is a great thing to have if you run into trouble on the mountain.
Here is something i try to do . . .
When i am working on the sled doing basic things in the garage, i use only those tools in the tool kit on the sled. If i don't have some necessary item in there, then i add it. Between myself and my riding buds, we usually have about anything needed to do basic repairs/adjustments out riding. This has been helpful too when we come across others who have had breakdowns and are less prepared. You would be surprised how many think a leatherman, and a few wrenches are all that is needed.
My tool kit is probably 5 lbs and fits inside a 3 x 3 x 9" (approx.) tool pouch, wrapped in plastic as I don't like to get them wet.
The Following User Says Thank You to Timbre For This Useful Post:
  #5
Old 10-13-2017, 09:18 AM
Currently: Not set.
Default
I forgot to mention the best tool..... Hose clamps! After I get the tools in my bag, what ever room is left i fill up with good quality (made in the USA) hose clamps, several sizes.
They can be used for so much more then clamping a hose. They are great for fixing several broken suspension parts.
This pic is from about 6yrs ago but this is one way to fix a broken rod end with a wrench and hose clamps. Rode the rest of the day with this repair.
The Following 3 Users Say Thank You to SRXSRULE For This Useful Post:
breisma (10-19-2017), RanOutofTalent (10-13-2017), Snowman.PRO. (10-29-2017)
  #6
Old 10-13-2017, 05:20 PM
Timbre's Avatar
Default
WOW! that little "fix" was pure genius!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — new burandt handlebar bag and large lock and ride tunnel bag Thread Starter — m7extreme Forum — Misc. Sled Parts Replies — 7 Last Post — 09-22-2016 03:10 PM
Thread — Wtb Underseat bag or skinz tunnel bag for 13+ pro. Thread Starter — m7extreme Forum — WTB (Swapmeet) Replies — 0 Last Post — 08-29-2015 03:06 PM
Thread — Tunnel Bag / Rear Rack Bag for 2002 RMK Thread Starter — OldRMK800 Forum — Polaris: EDGE Replies — 4 Last Post — 10-02-2009 03:26 AM
Thread — Tool bag, organize your tools. CUSTOM - water resistant Thread Starter — racingpit Forum — Seats (Swapmeet) Replies — 1 Last Post — 02-22-2008 07:18 AM
Thread — Tool bag, organize your tools. CUSTOM - water resistant Thread Starter — racingpit Forum — Misc. Sled Parts Replies — 0 Last Post — 02-15-2008 01:22 PM
